Date/Time: Sat, 15 Mar 2025 16:03:01 +0000
Vpoc Migration
View Count: 621
[2022-07-26 15:14:55]
Jaydtrade - Posts: 88
I am sure there is a study for it I just can't seem to locate it. I am lookin for something that shows the vpoc line at price as it migrates throughout the day. Similar to what bookmap has. Thanks!
[2022-07-26 17:15:22]
John - SC Support - Posts: 38678
The study you want is called "Volume Value Area Lines" and you want to set the Input for Draw Developing Value Area Lines to Yes. You can also turn off the Value Area Lines subgraphs if you do not want those by setting the Draw Style to Ignore.
Refer to the following:
Chart Studies: Ignore (ACSIL: DRAWSTYLE_IGNORE)
[2022-07-26 18:17:04]
You can also do this with the Volume by Price study:
Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines
