Date/Time: Sat, 15 Mar 2025 16:07:49 +0000
Cant access to binance future charts when using service trading evaluator
View Count: 400
[2022-07-25 19:06:47]
Defiable - Posts: 3
Cant access to binance future charts when using service trading evaluator do you know why ?
[2022-07-25 19:30:09]
John - SC Support - Posts: 38678
The Binance symbols are not setup to be used with the Trading Evaluator.
If you want to be able to chart them while using the Trading Evaluator, then we recommend installing a second Sierra Chart and leave the Global Settings >> Data/Trade Service Settings >> Common Settings >> Current Selected Service set to SC Data - All Services.
Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2022-07-26 12:53:07]
Defiable - Posts: 3
ok but can i set with this service a balance ? and can i get profit in usd because i did everything in the settings and still get C and not USDC
[2022-07-26 13:51:44]
We will add support for this now:
The trading evaluator service definitely does support an Account Balance but will not support trading Binance symbols.
If the symbol you are trading is already denominated in USD you will not see USD.
[2022-07-26 18:03:45]
Defiable - Posts: 3
Thank you for your fast support can you write a message in this topic when the feature to use trader evaluator on binance chart will be added
