Date/Time: Sat, 15 Mar 2025 16:03:04 +0000
Cannot Reduce Candle Body Width On Footprint Charts
View Count: 1179
[2022-07-25 16:38:45]
User437317 - Posts: 6
I have attached a screenshot of a Footprint Chart using a combination of Candlesticks and Footprint bars. I am attempting to squeeze the width of the candle bodies to fit BETWEEN the bid and ask columns on the footprint chart so that I can show the price action inside each footprint bar. As you can see by the attached screenshot, the candle bodies overshadow the bid and ask columns.
However, after a diligent search of all Graphics Chart Settings (both Global and Chart specific), I have been unable to locate a setting which controls the width of the candlestick bodies, and which would enable me to shrink the width of the current candle bodies.
Any help in this regard would be much appreciated.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=67118
[2022-07-25 17:49:41]
John - SC Support - Posts: 38678
On that particular chart, do the following:
- Select Chart >> Graphics Settings - Chart.
- Either deselect, or ensure that the option is not selected for Use Global Graphics Settings Instead of These Settings.
- Select the Other tab.
- Change the value for the Candlestick Width % to a smaller value, start with around 10.
- Select Apply to see the changes on the chart. Adjust the Candlestick Width % as needed.
The above is assuming that you are overlaying the specific chart's Main Price Graph onto the Numbers Bars.
