Date/Time: Sat, 15 Mar 2025 16:07:49 +0000
Shortcuts
View Count: 391
[2022-07-25 16:29:39] |
User493647 - Posts: 5 |
Hello is there a list of all keyboard shortcuts already assigned on sierra? Thanks.
[2022-07-25 17:37:27] |
John - SC Support - Posts: 38678 |
There is not a way to list all of the keyboard shortcuts. But there are a few options to see what is being used. First, any keyboard shortcut that is associated with an item on the pulldown menu will show in the pulldown. Second, on the Keyboard Shortcut window, when you enter a key combination, it will tell you if that combination is already in use and what it is assigned to. Refer to the following for more information: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-25 18:09:06] |
JohnR - User831573 - Posts: 320 |
Maybe this is something that can be added to the documentation. A full list of keyboard shortcuts that are assigned by default to start with. JohnR |
[2022-07-25 19:00:16] |
OK. Yes that's a good idea, thanks for your answer.
