Date/Time: Sat, 15 Mar 2025 16:05:24 +0000
EUREX Symbols not working today
View Count: 385
[2022-07-25 15:04:19] |
User80177 - Posts: 29 |
Hi, The flwg symbols are showing in InternactiveBrokers' TWS but not working in Sierrachart. Can you suggest a solution? Thanks ESTX50-202209-DTB-EUR-10 DAX-202209-DTB-EUR-25 TICK-IBIS-IND-IBIS |
[2022-07-25 15:38:05] |
We have updated the Interactive Brokers EUREX Symbol Settings and changed -DTB to -EUREX due to a change from Interactive Brokers today. Follow the instructions here to update the Symbol Settings within Sierra Chart: Global Symbol Settings: Update Global Symbol Settings You also need to update the -DTB to -EUREX for symbols in existing Charts, Trading DOMs and Quote Boards within Sierra Chart. Instructions: Changing the Symbol of a Chart The updated EUREX symbols are listed in File >> Find Symbol >> Futures-EUREX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-25 15:40:55
