Date/Time: Sat, 15 Mar 2025 16:10:14 +0000
Volume Profile Speadsheet
View Count: 413
[2022-07-25 05:07:29] |
Sergio Hernandez - Posts: 23 |
Hi SC Support, I'm trying to build a statistical study that is based on RTH opening price and the previous days VP. I've been able to generate a spreadsheet based on the VP studies I have on my charts, but I notice the values do not change after the open. For example if 7/22/22 RTH opens with the POC at 3961, than the POC column remains showing 3961 for the entirety of the day, which is based on 5 min chart. Ideally I would like to see the POC shift, etc. I'm clearly missing something so any help would be appreciated.Thanks! Best, |
[2022-07-25 15:45:10] |
John - SC Support - Posts: 38678 |
How are you getting that Point of Control value?
[2022-07-26 03:30:34] |
I'm honestly not quite sure. I'm selecting the spreadsheet study, which in turns captures the studies on the respective chart onto a spreadsheet. Looking at it now it seems its plotting the POC at close rather than at open as previously mentioned. After further review 7/22 RTH opened with a POC around 4006 price and ended at the 3961 price. Is there a setting I have to modify to capture the entire sessions POC shifts? this is also in regards to VAH,VAL. |
[2022-07-26 16:32:04] |
Set the Input on the VbP for Calculate Developing POC and Value Area to Yes. Refer to the following: Volume By Price Study: Calculate Developing POC and Value Area For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-27 02:52:22] |
Thanks, John.
