Date/Time: Sat, 15 Mar 2025 16:03:03 +0000
Add on Orders Attached Orders Go To The Original Attached Orders Location
View Count: 475
[2022-07-25 03:29:23]
SabikiSensei - Posts: 76
Before, if my second/third order was entered above or under my first order, then the TP/Stop loss would also be slightly above or below the initial attached orders. Now the TP/Stoploss go to wherever the original attached orders are currently. I'm not sure what setting I changed, how do I change this back?
[2022-07-25 15:38:57]
John - SC Support - Posts: 38678
It sounds like you have the option for "Scale In" enabled. Refer to the information here:
Attached Orders: Scaling In
[2022-07-26 00:42:40]
So if I use the scale in feature, it is recommended to not ever use the flatten and cancel all trades button?
[2022-07-26 04:36:39]
You can still use the flatten and cancel operation.
