Date/Time: Sat, 15 Mar 2025 16:03:04 +0000
Question about CQG Order Routing
View Count: 420
[2022-07-25 03:25:42]
superboris - Posts: 9
Dear Sierra Chart Engineers,
I have a question about CQG order routing. I see from the CQG documentation page that says:
Server Managed Bracket Orders: No
I wanted a bit of clarity. I understand that say, I place a limit order with an attached bracket order. Then I lose my internet connection. Then the limit order is filled while my connection is still down. At that point, until I restore internet connection, I do not have a stop in the market correct? I believe I understand that part properly.
My question is,
Say I submit a market order with attached bracket, or I submit a limit order with attached bracket, and this order gets filled BEFORE I lose my internet connection. After it is filled, I lose my internet connection. Are the attached bracket orders sent to the market at that point, or in this scenario am I still without a stoploss if my Internet connection goes down?
Thank you for your time
[2022-07-25 05:14:22]
Yes this is correct:
How this all works is documented here:
Attached Orders: Management of Attached Orders when Trading Service Supports Server Side OCO Only
We definitively recommend Teton order routing. Unless there is a reason you need to be using CQG, do not. Use Teton order routing instead:
