Date/Time: Sun, 16 Mar 2025 06:11:12 +0000
I cannot install. The. Update.
View Count: 399
[2022-07-24 16:28:47] |
User134198 - Posts: 3 |
I cannot store the update.
[2022-07-25 15:22:35] |
John - SC Support - Posts: 38678 |
Please do the update one more time, and when it completes (and fails), select the button in the upper right corner for Send Log to Support. Then let us know that you have done this in this thread and we will take a look and see what it states. Or, you can use the Zip installer, which is available at the following link: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-26 10:31:34] |
This could be a file permission related issue. Refer to: Software Download: Resolving 'Access is Denied' Errors What folder is Sierra Chart installed to on your system? It must only be installed to C:\SierraChart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-26 10:32:39
