Date/Time: Sat, 15 Mar 2025 16:10:13 +0000
[User Discussion] - Performance with mixing docked / floating windows
View Count: 477
[2022-07-23 08:38:17] |
BenjFlame - Posts: 335 |
Hi, 1) are there any negative performance penalties when mixing charts: some are floating, and others are docked in the chartbook? The floating charts have study overlays from the docked charts. 2) Are there any performance penalties when some floating charts are on different monitors, each with their resolution and refresh HZ rate? |
[2022-07-25 14:46:48] |
John - SC Support - Posts: 38678 |
1) No, there are no penalties to this setup. 2) No, there are no penalties to this setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
