Date/Time: Sat, 15 Mar 2025 07:58:25 +0000
So very confused about AMP and CQG
View Count: 924
[2022-07-23 04:11:42]
User427371 - Posts: 14
SC version 2394 states "CME Group and EUREX market data is no longer supported through CQG."
Well, I am with AMP. So does this mean that I am not able to use the newer versions of SC? I actually don't have an account with you anymore. I'm thinking about coming back to Sierra Chart, but there is no point if I can't use AMP as a broker and AMP does not use Teton/Denali.
If I come back to Sierra Chart will I need to use an early version in order to connect through AMP as my broker using CQG? It seems like your support for them is going away. I don't want to come back to Sierra Chart just to not be able to use AMP in the near future.
Thanks in advance for any instructions on how to make this work.
[2022-07-23 07:43:43]
You just need to use the Denali Data Feed for market data. You can still use CQG for trading. This is all explained here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394
No you do not. You can use the current version.
Date Time Of Last Edit: 2022-07-23 07:44:27
