Date/Time: Thu, 19 Sep 2024 17:14:20 +0000
Point and figure
View Count: 1054
[2014-05-08 12:51:21] |
User36082 - Posts: 4 |
Is there a way to base the point and figure chart study off of the close rather than the high/low?
[2014-05-08 19:19:35] |
No. Unless you modify the study. The study code is provided with Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-08 19:19:52
