Date/Time: Sat, 15 Mar 2025 16:05:23 +0000
Difference in Chart Setting form view
View Count: 437
[2022-07-23 00:09:17] |
user 93611 - Posts: 2 |
When reading the "Overview of Trading" user manual under "Essentials Settings for Trading" it instructs you to select Chart >> Chart Settings. It shows a picture of the form you should see when doing so. It is a standard windows form with fields, checkboxes, dropdowns, etc. I attached it as Image_From_Manual.png When I right-click on Chart >> Settings on my chart, it opens a different appearing form, one with a list of setting names on the left and a list of values on the right. The Image from the Manual has 3 tabs at the top. the form I get when selecting chart settings has 16 sub-forms listed at the top. I have included what I see as Image_From_Sierra_Charts.png. Why don't I see the same in both places? and how do I fix it? |
![]() Attachment Deleted. ![]() |
[2022-07-25 12:55:23] |
We will update this documentation today.
[2022-07-26 10:24:34] |
The documentation is now updated: Overview of Trading: Essential Settings for Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
