Date/Time: Sat, 15 Mar 2025 07:58:23 +0000
Pin the DOM to a Single Chartbook
View Count: 442
[2022-07-22 21:43:35] |
GreenScreen - Posts: 4 |
. Ability to “pin” the DOM window to a single Chartbook, not a global window, whereas it currently floats on top of the Chartbooks. . |
[2022-07-22 21:46:45] |
John - SC Support - Posts: 38678 |
The Trading DOM can be "pinned" (attached) to a chartbook. By default it is detached, but you can attach it. Refer to the information here: Detaching and Attaching Chart Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
