Date/Time: Sat, 15 Mar 2025 16:00:36 +0000
Changing 'Trade Window' orintation
View Count: 646
[2022-07-22 20:48:39]
Makusan - Posts: 15
I have looked through the manual regarding setting up and customizing the 'Trade Window', and there is NO mention or instructions on how to change the TW from a Vertical orientation to a Horizontal orientation.
If this is not currently possible, then I'm making a request for this idea to be passed onto the "upgrade" department.
Thank you.
[2022-07-22 20:53:51]
John - SC Support - Posts: 38678
You can accomplish this by using the Control Bar to setup a "Trade Window" how you want. Refer to the following:
Basic Trading and the Trade Window: Control Bar Trading Shortcuts
As for the Trading Window as it exists today, we are working on changing all the windows using our new format (the Settings windows are using this format now). Therefore, we are not doing any work on the existing window. We will see if there is a way to incorporate your suggestion in the new window.
[2022-07-25 09:15:14]
Makusan - Posts: 15
Hi John-SC Support,
Thank you for your reply and the reference link has nothing to do with my question. So I'm attaching two pics to show you the orientation of 'trade' windows 'vertical' and 'horizontal'. Currently, SC's 'trade window is fixed in a 'vertical' orientation, and it would be great if there was a way to toggle to a 'horizontal' orientation also.
Please pass this idea onto the department that makes these type of changes.
Thank you for your time.
imageSC-TradeWindowVertical.png / V - Attached On 2022-07-25 09:12:52 UTC - Size: 10.63 KB - 135 views
imageSC-TradeWindowHorrizonal.png / V - Attached On 2022-07-25 09:13:11 UTC - Size: 37.38 KB - 153 views
