Date/Time: Sat, 15 Mar 2025 07:58:25 +0000
accessing trade activity log via ACSIL
View Count: 972
[2022-07-22 20:22:42] |
onnb - Posts: 662 |
Looking to double check on something Is there an api to access the trade activity log? Specifically looking to access the order rows one by one. |
[2022-07-22 20:48:52] |
John - SC Support - Posts: 38678 |
Refer to the information starting at the following: Automated Trading From an Advanced Custom Study: Getting Order Information For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 21:26:28] |
onnb - Posts: 662 |
Thanks, I think from that I can: 1. Retrieve current status of orders 2. History of fills for an order I'm looking to see if I can retrieve the full Lifecyle history of the order as it was in the trade activity log as it goes through pending, open, modifications, rejection/errors, etc. I.e., all the rows for an order throughout its lifecycle. Another option I was looking to see if there is an api to programmatically filter and then save the trade activity log. For my purposes that might have achieved the same thing. |
[2022-07-22 21:42:37] |
All of the information you are wanting can be retrieved through one or more of the functions in that section. In particular, note the ones that return a reference to a s_SCTradeOrder structure. You will find the information on this structure here: Automated Trading From an Advanced Custom Study: s_SCTradeOrder Structure Members For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 21:56:32] |
onnb - Posts: 662 |
Taking an example, say an order had the following activity Opened at some price x Then gets modified 3 times Then gets filled and is no longer active For example, using the api I can get details on the 3 modifications? When they happened, the original price and the new price, original quantity and new quantity, etc? |
[2022-07-22 22:04:43] |
You would have to call the function at different times to gather the information at each stage. You would then need to save what information is important to you.
[2022-07-22 22:17:30] |
onnb - Posts: 662 |
Makes sense, thank for confirming, sorry for not explaining it better from the start. What you described doable and would probably work most of the time but I would think its not 100% reliable as there is at least the potential to miss order updates. |
