Date/Time: Fri, 25 Sep 2026 10:39:40 +0000
Seirra Chart freezes
View Count: 642
[2022-07-22 20:19:01]
Joel Wisdo1 - Posts: 15
Where there changes made to the current release? I have chart that freezes now when I open it. I have been working on it for the last 8 months and now it will not open on Sierra Chart. I am still using the same machine. Nothing has changed on my end (hardware nor software) on my end. Just checking if something was changed with the current release. I have turned off my virus software and went through your check list but no luck.
[2022-07-22 20:44:19]
John - SC Support - Posts: 48003
There are always changing occurring, but nothing that should cause an issue with opening a chartbook that has been kept up to date.
But, if you made a large jump in versions, then it is possible that the chartbook is not compatible with the current release. Refer to the following if this is the case:
Chartbooks (Workspaces): Opening Older Chartbooks
If the above does not apply, then please attach the Chartbook to this thread for us to take a look at it. Refer to the information at the following link for how to attach a file:
