Date/Time: Tue, 26 Nov 2024 11:37:55 +0000
SC_UPVOL/SC_DOWNVOL
View Count: 1244
[2014-05-08 11:56:05] |
User61322 - Posts: 8 |
I want to use sc.BaseData[SC_UPVOL][sc.Index] and sc.BaseData[SC_DOWNVOL][sc.Index] .Checking the data I receive sc.BaseData[SC_UPVOL][sc.Index] + sc.BaseData[SC_DOWNVOL][sc.Index] = sc.Volume[sc.Index]. This should not be valid for all sc.Index values. As you often can find two subsequent trades at the same ask or bid price. I use SC 1132 1 Minute Bar period chart - intraday Split data records - unchecked intraday data storage time unit - 1Tick I have sc.MaintainAdditionalChartDataArrays = 1 And I use Sierra Chart Real Time and Historical Exchange data Can you please have a look at it. Thank you. |
[2014-05-08 19:07:07] |
This is to be expected. We will make sure the documentation explains how this works.
[2014-05-08 19:21:53] |
The documentation has now been updated. It can be found here: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseDataIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-12 11:54:17] |
Thank you I understand it now in a different way.Kind Regards.
