Date/Time: Fri, 29 Mar 2024 14:57:33 +0000
[User Discussion] - Time increments at bottom of chart
View Count: 2143
[2013-04-27 19:17:53] |
madra - Posts: 109 |
Hello, Is there a way to reduce the time increments at the bottom of the chart? Note at he bottom chart 7:21,7:35, 8:11 13:30,13:57 etc I want to be able in examining my intraday trades to pin point the entry and exit times. Thank you for the help http://www.sierrachart.com/image.php?l=1367089743948.png |
[2013-04-27 19:22:07] |
M5amhan - Posts: 468 |
try going here global settings>tool settings>chart values tab>check seconds at the bottom Edit: sorry this is for crosshair only, may be able to help though if you use a crosshair for examining Date Time Of Last Edit: 2013-04-27 19:23:09
[2013-04-27 19:44:11] |
Thank you 51479, I think that I have figured out what the issue is. This a Point and Figure chart so the x axis is not based on time but on the movements of the chart columns. So a new time will be registered only when a new column of x's or o's begins. A new column could take 5 minutes to 20 minutes to form. Thanks for the crosshair idea this has helped me figure out the above. All the best, charlie |
