Date/Time: Sat, 15 Mar 2025 07:53:30 +0000
Chart DOM prices skipping
View Count: 610
[2022-07-22 19:39:30] |
User550539 - Posts: 34 |
Hello, I have been using market depth with my chart DOM for all futures products (ES, CL, GC, etc), for some reason when I open the treasuries (ZN, ZB, UB, etc) the price on the chart DOM starts to skip prices and does not display any values in between. The tick values are set correctly in the symbol settings, not sure what else it could be. Hoping you could help |
![]() Attachment Deleted. |
[2022-07-22 20:05:07] |
John - SC Support - Posts: 38678 |
The first thing to check is whether you have anything entered in the Scales Window for Scale Increment. This should be set to 0 unless you want a specific spacing for your prices. Refer to the information here: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) If it is not the Scale Increment, then you would need to double check the Tick Size setting in Chart >> Chart Settings >> Symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 22:40:40] |
Scale Increment worked for me thank you.
