Date/Time: Sat, 15 Mar 2025 16:10:12 +0000
Numbers bars calculated values on TSLA daily chart
View Count: 385
[2022-07-22 16:52:59] |
Mustang77 - Posts: 122 |
Hi The above mentioned study does not work on TSLA daily chart, only works on LTF like 4H see photos attached Thanks |
[2022-07-22 17:18:24] |
Yes that is true. That study cannot be used on Historical Daily charts.
[2022-07-25 10:00:55] |
Hi So it should work on intraday chart? |
[2022-07-25 11:38:13] |
Yes, but very important to refer to this help topic subsection regarding this: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-25 11:38:24
