Date/Time: Sat, 15 Mar 2025 16:07:48 +0000
alert code does not work
View Count: 369
[2022-07-22 13:02:06] |
User360283 - Posts: 513 |
Help please 0 this code does not seem to work It does not seem to evaluate the "Id18<0.98" test Thanks =and(id18<0.98,O>C[-1]) |
[2022-07-22 15:15:03] |
Sawtooth - Posts: 4183 |
You also need the SG#: =and(id18.sg1<0.98,O>C[-1]) |
[2022-07-24 07:15:41] |
Make sure you are using the correct Subgraph number: Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
