Date/Time: Sat, 15 Mar 2025 16:07:47 +0000
Alerts
View Count: 413
[2022-07-22 09:21:03] |
User886069 - Posts: 17 |
Is there any way make alerts visible - like in TOS , line or at least Sth to indicate that there is alert there
Attachment Deleted. |
[2022-07-24 07:16:48] |
You can use a Horizontal Line drawing and set an alert on that: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line Chart Drawing Tools: Chart Drawing Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
