Date/Time: Sat, 15 Mar 2025 07:56:01 +0000
Binance Data Randomly Stopping
View Count: 476
[2022-07-21 21:42:32] |
SAEKOUS - Posts: 2 |
Hi! So I´m having these issues while looking at Binance BTCUSDTPERP contracts data, where suddenly Sierra will stop updating data in real time without any warning or anything. I tried to disconnect and connect, and even restart Sierra Charts, sometimes this might solve the issue, but generally not. My software is updated with the last version Thanks, in advance! Wishing you all an happy Friday! |
[2022-07-22 11:33:57] |
This is a problem with the source Binance data feed. We are seeing if we can help with the issue but it looks increasingly likely that we cannot. But we will do our best. More work will be done on it next week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-23 05:05:01] |
Pooja Shejwalkar - Posts: 1 |
I am Facing Same Problem . Did You Find Any Solution ?
