Date/Time: Thu, 24 Sep 2026 20:25:01 +0000
historical NQ chart
View Count: 918
[2022-07-21 19:39:56]
User411320 - Posts: 377
which symbol will give me all of NQ historical data chart?
[2022-07-21 20:00:08]
John - SC Support - Posts: 48001
The best way to find the particular symbol you need is to open the File >> Find Symbol window. Then go to the appropriate exchange and find the entry you are looking for.
If the information on our servers is correct, then you are using our Teton Order Routing Service, in which case, the general symbol format for NQ for this service is NQ?##_FUT_CME. You find this in the Find Symbol window under the CME exchange. Then open this section to see the individual contracts and select what you want.
Also, refer to the section of the documentation on Continuous Futures Charts at the following link:
Denali Exchange Data Feed: Connections
[2022-07-21 20:01:44]
[2022-07-21 22:07:00]
Hello John,
so I did what you said and I only see contracts for this year. Also, I clicked the link you sent me and don't see anything about continuous contracts.
The reason I want all of NQ data, is because I want to do monthly volume profiles and want to back test
[2022-07-21 22:27:58]
So I was able to get data until 2010 for the Nasdaq by changing the chart settings. How can I get it to the inception of the Index?
Date Time Of Last Edit: 2022-07-21 22:30:16
[2022-07-21 22:30:40]
58LesPaul - Posts: 429
Continuous Futures Contract Charts
Go to Chart >> Chart Settings >> Symbol, 5th item down is Continuous Contracts
[2022-07-21 22:32:49]
Hello LesPaul,
Tanks for responding, I actually just figured that out but my data only goes back to 2010. trying to figure out how to get until inception of Nasdaq
[2022-07-22 17:20:44]
That is as far back as we have the data. Refer to the information at the following link for how far back our data goes:
Sierra Chart Historical Data Service: What is Included
[2022-07-22 18:09:36]
There is at least 20 years of historical daily data available for NQ futures. Not 10 years.
You should have no trouble accessing it. You need to use a Continuous Futures Contract chart.
If there is any data missing, refer to:
Date Time Of Last Edit: 2022-07-22 18:09:53
[2022-07-23 19:40:15]
This worked, I got the data all the way back to 1999. thank you all for your help!
