Date/Time: Sat, 15 Mar 2025 07:55:59 +0000
sc.PriceValueToTicks() function can't handle negative values
View Count: 370
[2022-07-21 18:06:24] |
DabbaDo - Posts: 148 |
This method returns an unsigned int, so it returns UINT_MAX (almost) when given a negative price (e.g. from TICK-NYSE) Maybe not a bug, but a bit surprising. FWIW, Dale |
[2022-07-21 19:30:10] |
Will check.
[2022-07-21 20:25:11] |
We are going to update the function to return a 64-bit signed integer.
