Date/Time: Sat, 15 Mar 2025 07:56:00 +0000
DOM Faulty
View Count: 330
[2022-07-21 16:15:52]
User554643 - Posts: 5
Hi, part of the DOM is always covered by these bars for some reason and i havent change a setting(this can be clearly seen on the picture which i have attached with this ticket). I already reported this problem but it has not been fixed yet.
imageDOM.JPG / V - Attached On 2022-07-21 16:15:41 UTC - Size: 34.61 KB - 124 views
[2022-07-21 18:24:52]
John - SC Support - Posts: 38678
We assume that you are referring to the Volume Bars that are displaying in each of the columns. You would need to turn off those Volume Bars for each of the columns in which you do not want them. Refer to the information here:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
