Date/Time: Sat, 15 Mar 2025 07:58:24 +0000
Trade window - drop down options just below title bar
View Count: 471
[2022-07-21 14:31:45]
User 144164 - Posts: 17
How to delete all the many types of trade orders except 3
These are only orders I use:
1. Stop
2. Trailing Stop
3. Target
They are all under simple bracket
Thank you
[2022-07-21 18:17:25]
John - SC Support - Posts: 38678
There is not a way to change the list of order types.
If you are asking something else, then we need more information to understand what you are asking about.
[2022-07-21 19:10:16]
220721-1411
Thank you for your fast reply.
I do not want to change any of the types.
I want to DELETE all of them from the list except for the 3 that I use noted in last message.
Thank you
[2022-07-21 19:16:19]
220721-1416
If they can NOT be deleted, is there a way to HIDE the ones not used?
Thank you
[2022-07-21 19:45:23]
There is not a way to change the list.
[2022-07-22 09:06:59]
What you can do is customize the Chart Trade menu and list the order types that you want there:
Global Settings Menu: Customize Chart Trade Menu (Global Settings menu)
