Date/Time: Sat, 15 Mar 2025 07:58:25 +0000
No connection
View Count: 320
[2022-07-21 13:10:32] |
Carol Rutherford - Posts: 66 |
I downloaded the latest software version and renewed my service package. I cannot connect. When I renewed I couldn't see where to renew for a service package of 10 or higher. Can you please help with this? I can add more money if necessary. I just don't see how to do it. Carol Rutherford |
[2022-07-21 18:08:57] |
John - SC Support - Posts: 38678 |
We have set your account to evaluate package 12 for the next 60 days. This means that you do not need to change your service package at this time, and you will now be able to connect to Interactive Brokers. Just keep in mind that this is an evaluation, therefore you need to keep your Package 3 during this same time period. To change your package when this time has ended, follow these instructions: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
