Date/Time: Sat, 15 Mar 2025 07:53:27 +0000
service package 5 with real time data
View Count: 797
[2022-07-21 09:02:14] |
User658185 - Posts: 3 |
hello everyone. I have been searching through posts but really im confused.can someone please tell me what services do i need for my trading? i only trade us30 and i want real time(not delayed) footprint,dom,delta,volume and tpo profile. except service package 5 which i want to active do i need to buy anything else or not? if yes what is the most afordable to active or buy? thanks a lot Date Time Of Last Edit: 2022-07-21 09:03:21
[2022-07-21 12:24:03] |
Do you need real-time futures data? We would think so based upon your requirements. What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-21 12:24:12
[2022-07-21 19:59:46] |
thanks for reply. i forgot to say that i only need sierra platform and data for my analysis and my trading platform and broker will not be sopported or connected to sierra. and yes i need real data(not delayed) |
[2022-07-21 20:21:26] |
John - SC Support - Posts: 38678 |
We need to know if you are looking for the CFD data for the US30, or if you are wanting the Dow Jones Industrial Average futures? The futures are traded on the CBOT exchange within the CME Group. But, in order to get the data from the CBOT (or any of the CME Group exchanges) at the non-professional rate, then you need to have a live, funded, futures trading account. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-21 20:31:43] |
look I just want everything that i use in trial plus recieving data with zero delay. for this i need a live funded acount? |
[2022-07-21 20:50:36] |
To begin with, if you want real-time futures data, then you will have to pay for it. The only real-time data that does not have a cost is CFD and FOREX data. We really recommend using our Delayed Streaming data while on the trial, as the data acts like real-time data, so you can get used to using the system without having to pay for real-time data. Whenever you want to switch to real-time data, you will need to be on one of the Integrated Packages and then setup the data you want. For the CME Group data, you will need to have a live, funded, futures trading account to which you can connect your Sierra Chart software for verification, in order to get the data at the non-professional rate. This is a CME Group requirement, not ours. Again, the information on this is at the following link: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges In order to setup the data for the CME Group, you will need to follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
