Date/Time: Sat, 15 Mar 2025 07:55:59 +0000
OpenGL Text and Artifacts Issue
View Count: 744
[2022-07-20 23:43:17] |
User807771 - Posts: 12 |
nVidia GTX 1060 w/latest drivers, non-Bold Segoe UI font, SC v2394 "Text Display For Study" yields garbage text (See attached images). I am also getting some random pixels showing up between prices on the Y-Axis (in the same color as the price values) and overlapping artifacts from elements drawn on the chart from a studies (eg, Real Time Clock, or anything where you select the horizontal/vertical location). I enjoy the performance boost I'm getting from OpenGL, but Text doesn't look nearly as sharp in my configuration. Is there a suggested Typeface that would render better? |
![]() ![]() Attachment Deleted. |
[2022-07-21 04:41:47] |
Probably we cannot do anything to help with this. Try using a different Font style. A true type font. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-21 04:42:04
