Date/Time: Sat, 15 Mar 2025 07:53:27 +0000
TPO A period starts at 9.45 ET
View Count: 351
[2022-07-20 23:23:35]
TomasVill - Posts: 9
Hello there
My TPO chart works very well but I have noticed the time of the periods are quite different. For example, the RTH A-period (first period) starts at 9.45am instead of 9.30 market RTH open. Then B starts at 10.15am instead of 10am. I have been looking at the settings but cannot find it. Thanks for your help in advance. The time is set to NY time as usual.
[2022-07-21 18:01:07]
John - SC Support - Posts: 38678
The most likely issue is with the Session Times. Make sure they are set correctly and that your start is set to 09:30. Also, ensure that the ending time (for which ever session you are using) is set to 09:29:59. The documentation for Session Times is at the following link:
Chart Session Times
