Date/Time: Tue, 26 Nov 2024 11:58:33 +0000
trade activity log empty
View Count: 1150
[2014-05-08 09:45:42] |
User60591 - Posts: 39 |
hi, I updated sierra today from v.1109 and my trading activity log is empty. I dont have any data at all. can you help me with that? It's connection to Rithmic. When I start Sierra on the first popup screen it does not show request for trading data. thank you Date Time Of Last Edit: 2014-05-08 10:55:34
[2014-05-08 18:06:18] |
Make sure the settings at the top of the Trade Activity Log are correct. Here is the documentation for using the Trade Activity Log: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
