Date/Time: Sat, 15 Mar 2025 07:56:01 +0000
TPO Periods Half Back
View Count: 799
[2022-07-20 19:33:28] |
User664561 - Posts: 33 |
Hi - I can't find any documentation for the system to automatically mark on the TPO tick profile the "half-back" of each period. Witnessed it this morning on a Windotrader platform. thanks
[2022-07-20 21:55:02] |
John - SC Support - Posts: 38678 |
It is not a built-in option on the TPO. You would need to calculate it on a separate chart and then overlay it onto the TPO chart. The Halfback is just the average of the High and Low, or (High + Low)/2. There are multiple ways to get this information, but perhaps the simplest is to use the Study Subgraph Reference on the 1 day chart and reference the HL Avg from the Main Price Graph. If you want to view a previous day, then use the Displacement option. You can then use the Study/Price Overlay to overlay that on the TPO chart. Refer to the following: Study Subgraph Reference Chart Studies: Subgraphs Tab >> Displacement Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-20 23:28:51] |
Thank you very much. Maybe a suggestion for a built in..
[2022-07-21 04:43:49] |
This is already available. Refer to item 5 here: Time Price Opportunity (TPO) Profile Charts: How to Read TPO Profile Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-21 04:44:51
