Date/Time: Wed, 30 Oct 2024 22:56:04 +0000
The Chartbook file is not compatible. Contact support for help with converting it.
View Count: 3210
[2023-04-11 09:06:45]
Sierra_Chart Engineering - Posts: 16764
We are no longer converting these Chartbooks. You must contact the supplier of these and have them update them for the newer version of Sierra Chart. You should not even be using these older Chartbooks. Makes no sense.
Date Time Of Last Edit: 2023-04-11 09:07:19
[2023-05-26 08:15:19]
User419576 - Posts: 1
the message i'm getting while trying to display the chartbooks, (The Chartbook file is not compatible. Contact support for help with converting it.) charbooks worth thousands of dollars, i will be happy if you help me fit this version of sierra
Private File
Private File
[2023-05-26 09:41:27]
User137494 - Posts: 1
Hello Can you convert this file in latest?
Private File
Private File
attachmentG7FXSTAGE1PROFILECHARTBOOK-200608-010449.Cht - Attached On 2023-05-26 09:40:18 UTC - Size: 23.05 KB - 233 views
[2023-05-26 14:19:36]
John - SC Support - Posts: 35639
You need to get updated chartbooks from G7FX.
Or you can follow these instructions to update the chartbooks yourself:
Chartbooks (Workspaces): Opening Older Chartbooks
[2023-06-04 17:02:11]
User464318 - Posts: 1
can you please convert these.
attachmentG7FXFOUNDATIONDOMCHARTBOOK-200330-085855 (1).Cht - Attached On 2023-06-04 16:47:44 UTC - Size: 276.18 KB - 190 views
attachmentG7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2023-06-04 16:52:28 UTC - Size: 528.28 KB - 256 views
[2023-06-04 18:45:32]
j4ytr4der_ - Posts: 938
As posted previously, you're gonna have to contact the originator of the chartbook for an updated version.
[2023-06-11 09:58:31]
User563483 - Posts: 3
hello could I have some help converting this free chartbook I found online, I receive this message in the message log "The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\MarketDepthHistoricalGraph+.cht | 2023-06-11 09:52:29.241 *" thankyou in advance for any possible assistance
attachmentMarketDepthHistoricalGraph.cht - Attached On 2023-06-11 09:56:00 UTC - Size: 76.96 KB - 159 views
[2023-06-11 16:02:57]
See here.
The Chartbook file is not compatible. Contact support for help with converting it. | Post: 343996
[2023-06-11 20:45:21]
sadface
[2023-06-14 00:39:39]
mbarbhaya - Posts: 37
