Date/Time: Sun, 16 Mar 2025 00:05:12 +0000
Chart missing
View Count: 632
[2022-07-20 12:45:40] |
User648702 - Posts: 48 |
I unplugged my second monitor to attach a new monitor and now one chart is missing. When I restart the software it is there but not showing op on the bottom list of charts and when I click on it, it disappears. I have looked behind all charts and it is just not anywhere but if I restart the software again then it reappears until I click on it and once again it disappears.
[2022-07-20 13:09:39] |
I found it. I had dragged my main Sierra Charts to another monitor and just dragged it back to the original screen and there it was. I just don't understand why I can't just drag charts instead of using Sierra charts "attach/detach chart". What if I want my main Sierra chart with all the charts in it to a new monitor without it hiding charts behind it. Another confusing thing is that whether the chart is attached or detached then the choice to detach or attach shows both instead of just one option. If the chart is already detached then the only option that shows up should be attach chart so it's less confusing.
[2022-07-20 16:03:48] |
Ok we will look at making this more clear.
[2022-08-04 15:00:23] |
I'm having similar problems. Any update on this? I spend allot of time just trying to find charts.
