Date/Time: Sat, 15 Mar 2025 08:00:59 +0000
Sim Trades data is empty
View Count: 392
[2022-07-20 11:57:11]
GreenAlien - Posts: 7
I am having issues with not being able to see the trades data in a second instance of Sierra.
Version: 2416
Using a separate SIM account SIM2 for the second Sierra instance.
I can see the Trade Activity, but the "Trades" tab is empty.
Attaching screenshots.
imageTradeActivity.png / V - Attached On 2022-07-20 11:56:21 UTC - Size: 27.02 KB - 116 views
imageTrades.png / V - Attached On 2022-07-20 11:56:26 UTC - Size: 20 KB - 113 views
[2022-07-20 14:06:35]
Make sure the Trades tab is not disabled:
Trade Activity Log: Menu Commands
Edit >> Disable Statistics, Trades, Period Tabs
[2022-07-20 14:31:28]
Yep. that fixed it. thanks!
