Date/Time: Sat, 15 Mar 2025 08:00:58 +0000
[User Discussion] - Importing chart file into c: data with crossover and mac...cant get to c: data to paste..
View Count: 427
[2022-07-20 11:02:28] |
User963878 - Posts: 1 |
Hi, Im trying to import a chart file into c: data with crossover and mac...cant get to c: data to paste.. I am on trial version for both crossover and Sierra if that matters? Thanks, Rob |
[2022-07-22 19:43:32] |
Tony - Posts: 554 |
I don't think 'trial versions for both' matters. Not sure what your procedure was, what I did was showing list of bottles, right click on Sierra, then I select 'Drive C:' in pop up menu, and Drive C folder for Sierra bottle will open, I can just open Sierra Chart folder and then Data folder, to move any files into that folder, very straight forward. When you said can't paste into data folder, did you get any error messages? |
