Date/Time: Sat, 15 Mar 2025 08:00:59 +0000
Spreadsheet - formating to seconds
View Count: 371
[2022-07-20 09:05:58] |
User361939 - Posts: 167 |
Hello, I am trying to get duration for bar in seconds. In excel it's a simple changing format [ss], so the difference in bar time is presentented in seconds. In spreadsheet i can only change format to time so i can see like at the attachment. What formula should i used so instead 0:02:50 i wil get value = 170 ? Best Regards |
[2022-07-20 14:01:56] |
Sawtooth - Posts: 4183 |
What formula should i use so instead of 00:02:50 i will get value = 170 ?
If you are using the Bar Time Duration study's output, try this: =MINUTE(ID1.SG1@3)*60 + SECOND(ID1.SG1@3) -where ID1 is the Bar Time Duration study. |
