Date/Time: Sat, 15 Mar 2025 07:58:24 +0000
Volume by Price study subgraph values not displaying in previous ranges
View Count: 453
[2022-07-20 02:29:38]
timobee - Posts: 3
I am trying to get the values to show for VAL and VAH on previous days sessions for the volume by price study. As you can see in the screenshot attached, the values are only displayed for the current or latest session. Please let me know if there is a way to fix this.
Also, I cannot get the POC to not display on the scale value to the right. I have tried changing the subgraph settings but cannot seem to remove this?
Last thing, is there a way to display the value in front of the volume profile so that they are not hidden? As shown in the screenshot, you cannot see the POC because it is hidden behind the volume profile.
Appreciate your help!
image2022-07-19 (13).png / V - Attached On 2022-07-20 02:28:52 UTC - Size: 450.55 KB - 117 views
[2022-07-20 13:52:17]
John - SC Support - Posts: 38678
Make sure you are using the Subgraph SG9 (Value Area and Outline) and set the Horizontal Alignment to "Left". You should get the value label showing in all the profiles that way. Refer to the following information:
Chart Studies: Subgraphs Tab >> Name and Value Labels
This is coded this way for the last profile to display in the Price Ladder. There is not an option to change it.
As noted above, you need to change the Horizontal Alignment to Left.
