Date/Time: Sat, 15 Mar 2025 07:56:00 +0000
Problem with time zone
View Count: 348
[2022-07-19 20:18:31] |
User203781 - Posts: 55 |
Since updating to the latest rev, Sierra Chart is displaying chart times as UTC +0, and that is the only option in the Time Zone Settings list. How do I fix this? Thanks.
[2022-07-19 20:45:49] |
John - SC Support - Posts: 38678 |
You need to click in the list on the right in the Time Zone Window to see the list of Time Zones. Refer to the instructions for that kind of field here: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
