Date/Time: Sat, 15 Mar 2025 07:53:28 +0000
Setting stops
View Count: 397
[2022-07-19 17:29:21]
User725404 - Posts: 5
If I have a stop limit set or just a limit order and I close sierra chart will the orders still work while closed?. when i closed sierra chart i got this message
imageScreenshot 2022-07-19 132507.png / V - Attached On 2022-07-19 17:28:28 UTC - Size: 10.88 KB - 111 views
[2022-07-19 18:33:05]
John - SC Support - Posts: 38678
In general, if these are part of an OCO order, then they will be at the exchange and you can exit Sierra Chart without worry. But, if they are a bracket order then it depends on your trading service. Refer to the information here:
Attached Orders: Introduction
[2022-07-22 07:41:33]
Sierra_Chart Engineering - Posts: 18789
The answer is yes.
