Date/Time: Sat, 15 Mar 2025 07:56:00 +0000
Chartbook/StudyCollection updates/conversions
View Count: 365
[2022-07-19 16:12:22]
Sawtooth - Posts: 4183
I have 16 Study Collections, and 4 Chartbooks, on my website that no longer work, and need to be updated/converted.
Please advise on the best way to accomplish this.
I don't mind doing this myself if you can give instructions.
Date Time Of Last Edit: 2022-07-19 16:43:20
[2022-07-19 17:01:12]
John - SC Support - Posts: 38678
For the Chartbooks, follow the instructions at the following:
Chartbooks (Workspaces): Opening Older Chartbooks
For the Study Collections, you can try the same process as the Chartbooks, but we are not sure when there was a change to the Study Collections format, so if you can't get them to load in version 2204, then you might have to rebuild them, as 2204 is as far back as we have the software at this time.
