Date/Time: Sat, 15 Mar 2025 07:58:23 +0000
Overnight High, Low and average lines from yesterday still on chart
View Count: 611
[2022-07-18 22:50:54] |
58LesPaul - Posts: 429 |
How do I make these overnight high, low and average lines to go away when a new trading day starts at 6pm? I used High and Low for Time Period and the Study Subgraphs Average studies and also the Study Subgraph Reference for each to extend the lines forward into the fill space. I can open the Studies Window and select OK and they disappear. I use the same Study Subgraph Reference for yesterday's high and lows but when a new day starts the old lines disappear. I've compared all my settings and they seem to be the same as yesterdays high and low. |
[2022-07-18 22:59:26] |
John - SC Support - Posts: 38678 |
As long as there is not a forced redraw of the chart, the previous items are going to continue to display on the chart. If you want to make them go away, then just recalculate the chart by selecting Chart >> Recalculate.
[2022-07-19 22:31:58] |
Chart >> Recalculate doesn't do anything. I have to open Studies Window and click OK. |
[2022-07-20 10:02:38] |
Yes that would make sense. Or use this command: Chart Menu: Reload and Recalculate (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
