Date/Time: Sat, 15 Mar 2025 07:56:00 +0000
Please reconsider CQG support
View Count: 401
[2022-07-18 18:35:38] |
User459170 - Posts: 262 |
Hi Sierrachart team, Please could you reconsider supporting CQG in higher versions of Sierrachart? What worries me is v. 2387 becoming unusable. Please support CGQ with newer versions even if you have to charge a higher price. Thanks for your help. |
[2022-07-18 18:40:15] |
CQG is still supported in all versions including the current version. Is that you want to use CQG market data for CME Group or EUREX?
[2022-07-18 20:10:22] |
Yes, for using CQG market data for CME. Thanks so much. |
