Date/Time: Tue, 26 Nov 2024 11:33:21 +0000
[User Discussion] - volume dist. paint bar study
View Count: 1021
[2014-05-08 03:48:21] |
gmorgan111 - Posts: 121 |
Is there more documentation on the volume dist. paint bar study. All the study description says is we can change colors. I would like to know what each setting is supposed to do. This sounds like a study I would like to try but I can not set it up correctly without knowing more about each setting. Thanks |
[2014-05-08 04:07:45] |
We do not plan any time soon to add more documentation for the study.
