Date/Time: Sat, 15 Mar 2025 07:51:02 +0000
SC not connecting to my data feed
View Count: 354
[2022-07-18 17:39:31] |
User414143 - Posts: 1 |
I had not been trading for a while after running my AMP balance below threshold. Just added funds to AMP and extended SC for 6 months. AMP says account is enabled for CQG but SC will not connect. Any idea if this is an issue on SC side? and if so how to correct? Message from SC on connect is: "Connect to Data Feed|Service Package does not support this function or account is expired."
[2022-07-18 18:37:54] |
This is resolved for your account. We provided your account access to Service Package 12 at no cost for 60 days. After that you need to change to Service Package 10 or 11 depending upon whether you were using Service package 3 or 5. Package 10 is equivalent to package 3 and package 11 is equivalent to package 5. Service Package 10 and 11 support connections to external services. For complete details, refer to: Service Package Changes | Discontinued External Services | Reducing Overall Costs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
