Date/Time: Sat, 15 Mar 2025 07:53:30 +0000
Different data on two SC
View Count: 367
[2022-07-18 16:37:09] |
User499894 - Posts: 48 |
Hi, I run two separated instances of SC, each on a separate PC, both configured exactly the same and connected to the same router by ethernet wire. I often see really different data on the two times & sales (also having the same exact settings) and I wonder what the reason could be: broadband connection? Denali? PC performance issues (the two PCs have very similar tech features)? What can I do to pinpoint the reason for such a thing and eventually correct it? |
[2022-07-18 19:40:32] |
John - SC Support - Posts: 38678 |
It's not going to be anything technical, it's got to be a setting somewhere that is different between the two systems. First, is this just in the Time and Sales that you are seeing differences, or are you also seeing differences in the chart bars? With the Time and Sales are you using any filtering or combining of trades? You would need to ensure these are set the same on both systems. Refer to the following: Time and Sales Window: Settings Menu For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-19 15:46:51] |
You are right, I did not realize I was looking at Mini-ES on a T&S and Micro-ES on the other one (the two source charts were not aligned). Thanks.
