Date/Time: Sat, 15 Mar 2025 07:56:01 +0000
Displaying Chart Question
View Count: 383
[2022-07-18 16:18:22]
Kellie Lacey - Posts: 75
Hi, is there a way of easily shrinking a chart, for example I have a chart going back to 1997 and want to be able to shrink itso can see most of it on the screen?
[2022-07-18 19:21:52]
John - SC Support - Posts: 38678
There is a limit to how much data you will be able to see on the screen at one time. The limit is hit when each bar is 1 pixel wide. We do not do any removing of data or interpolation in order to allow for more data to be seen at one time, as you may be missing the information you are looking for in this case. Refer to the following for how to change the chart bar spacing:
Working With Charts: Changing Bar Spacing
If you are unable to fit all the data on the screen when you have the spacing set to the minimal amount, then you would need to change your Time Frame for the chart to a larger time frame to fit more data. Refer to the following:
Changing Chart Bars Period
[2022-07-19 08:57:15]
ok thanks John will take a look, sometimes you can use your mouse the little rolling thing at top and that zooms chart in an out but not for these ones it seems
[2022-07-19 09:46:48]
Refer to:
General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll)
[2022-07-21 09:10:08]
Thanks John, I have just gone to amend some settings in chart session tab and it won't allow me to change anything, any idea why? it's not done this before? thanks
[2022-07-21 11:47:09]
We need to know the exact name of the specific tab. Are you referring to the Session Times tab in the Chart Settings window?
Date Time Of Last Edit: 2022-07-21 11:47:17
[2022-07-21 11:55:39]
yeah chart settings, then session times, can't change anything?
[2022-07-21 11:59:26]
You need to set the Chart Data Type setting also on that same tab to "Intraday Chart" and then click the A button.
Date Time Of Last Edit: 2022-07-21 11:59:35
[2022-07-21 12:07:40]
that's just it...it won't let me change it to Intraday, can't click on anything, and what is the A button please?
[2022-07-21 12:32:06]
Newer versions of Sierra Chart allow you to modify that setting on that particular Chart Settings tab, so you need to update Sierra Chart to the latest version following these instructions:
The A button means accept
Date Time Of Last Edit: 2022-07-21 12:32:24
[2022-07-21 14:01:51]
ah will I lose all my chart work I have done though?
[2022-07-21 14:37:59]
No not at all. Updating will not cause any of your configuration or Chartbooks to be lost.
Date Time Of Last Edit: 2022-07-21 14:39:12
[2022-07-21 14:48:01]
many thanks I've done that now
