Date/Time: Sat, 15 Mar 2025 08:00:58 +0000
FTX data
View Count: 545
[2022-07-18 16:13:50] |
User223281 - Posts: 58 |
Hello, how do I access FTX data?
[2022-07-18 19:16:51] |
John - SC Support - Posts: 38678 |
We see that you are using CQG - and we have not yet made the FTX data available when using CQG (it's a symbol updating thing). If you want to get the data now, you would need to install a second Sierra Chart and leave the Global Settings >> Data/Trade Service Settings >> Current Selected Service set to SC Data - All Services. You will then see the FTX available in your Find Symbol window (you will then open that section and then select the search button to see all the available symbols). Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-19 08:35:19] |
Sierra_Chart Engineering - Posts: 18789 |
FTX has been added when using CQG. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
